Re: 574 won't shift into 1st gear
Posted by caterpillar guy on October 11, 2010 at 10:51:33 from (66.188.53.165):
In Reply to: 574 won't shift into 1st gear posted by Kirk Affeldt on October 11, 2010 at 06:23:41:
I already posted to your dilemma in your previous post. Try looking there. It sounds like you need to adjust the length of your linkage some.or maybe your not getting 4th and think your not in 1st. The only adjust ment is under the guard for the lever. It comes off pretty easy just a couple of bolts under the guard front and back and one through the fender. With the guard off you will be able to shift it to find out if it is 1st or 4th you are not getting into.
