If the john Deer is set up with 3.5 or larger cylinders the Loader will lift all you need to lift with a 350. Unless the lift cylinders are set to have a short stroke, If they are 36 inch stroke they will be fine. two 3inch 40 inch cylinders on a Farmall H can lift 1000# with a 800 PSI belly pump. Jim
