Re: Farmall MD, SMD, SMDTA, 400 and 450 change to direct ...
Posted by Janicholson on October 11, 2010 at 18:31:01 from (67.72.98.45):
In Reply to: Farmall MD, SMD, SMDTA, 400 and 450 change to direct start? posted by Marty from MN on October 11, 2010 at 18:18:33:
There is no good way to do it. I have pull started my MD when I had a bad condenser in the Ignition.
Dragging it several hundred feet with it spinning much faster than a starter would do it, makes me a believer in its original system. It is not a very high compression diesel, and without glow plugs, or an intake heater equal to at least twice that found on the Continental 350D, it would not start.
It would not affect the engine head cracking issue if warmed up easily, and cooled down for 3 to 4 minutes.
Again, I believe they are one of the easiest starting diesels in below zero weather because they start on low compression gas. (you can crank start them! Jim
