Re: 53 Super H Hydraulics
Posted by Allan In NE on October 12, 2010 at 11:39:55 from (148.66.88.254):
In Reply to: Re: 53 Super H Hydraulics posted by Janicholson on October 12, 2010 at 10:25:13:
Jim,
All due respect back at ya, but that just simply is not true. Just another one of those old wives tales.
The "rear facing" port has an internal, mechanically activated "delayed drop" feature, but provides equal and simultaneous lift pressure; same as the forward facing ports.
All three ports are connected to the same darned puddle of oil. :>)
The delayed lift is accomplished only by the use of an external valve(read: smaller oil passage orifice) OR some other type of restriction (smaller hose?) in the pressure line to the cylinder.
These delayed lift valves originally came with the tractor when delivered new.
I’ve got the hydraulic schematic right here in front of me and can sure send it to ya if ya like.
If you've already got the schematic, I'd submit that you're following oil-flow backwards.
Allan
