Re: Hey Wardner
Posted by Wardner on June 20, 2000 at 15:17:48 from (63.23.216.124):
In Reply to: Hey Wardner posted by Pat on June 20, 2000 at 13:28:17:
Yep, I believe it is a Prince pump. They make two diferent sizes - one being a little thicker than the other.
12.8 GPM @ 2000 PSI at 540 RPM
23.0 GPM @ 2000 PSI at 540 RPM
I am not familiar with the Farmhand F11B loader. However, you will need double-acting cylinders for two way power. In most cases that will mean a pressure port at the top and bottom. The IH 3x8 cylinders used on the fast hitch have both ports on the top but an external pipe runs to the bottom. You will also need a four way open center valve to direct hydraulic flow. If it has a float feature that would be even better. I like to buy fittings and hoses from the Surplus Center in Lincoln NE. Tel 800-488-3407 to get a catalog.
Have fun. third party image
Post A Followup
: Re: Re: Hey Wardner
