Re: SMTA Axle Clicking
Posted by mkirsch on October 13, 2010 at 10:51:05 from (64.80.108.57):
In Reply to: SMTA Axle Clicking posted by IlliniJohn on October 12, 2010 at 18:10:50:
This may not be related, but one thing I found on my Super A was that the nuts were bottoming out on the threads before the bolt was tight.
When I got it, there was a creaking noise coming from one wheel. Found a loose bolt, tightened it.
Next time out, it was still creaking. Checked all the bolts. All were tight.
Still creaking. This time, I noticed that a TIGHT bolt would wiggle in the hole easily.
I ended up adding 2 lock washers to each bolt to get the nut far enough away from the shoulder that it would tighten down.
So, the bolts may be tight, but not TIGHT, if you know what I mean.
