The ideas below are good. I will add that the distributor shaft is bad if you can feel any play at all. Measure with a dial indicator in Up down/in out directions. .001 is max deflection. Any more and the dwell will be way off. If that still does not fix it, try the idea below.
If the altitude you are located at is above 2500ft, it might need a size larger main jet. (try setting the float 1/32 to 1/16" higher than stock, this will also deliver more fuel. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
