Re: Homemade hydro-static steering for W-400
Posted by Wardner on October 13, 2010 at 21:50:31 from (4.154.239.213):
In Reply to: Re: Homemade hydro-static steering for W-400 posted by J.J. from Afton on October 13, 2010 at 19:43:18:
J.J.
Stuff I have added so far:
rear fast hitch
front fast hitch pushed from reversed drawbar
50cfm air compressor driven by belt pulley gearbox
10kw generator driven from air compressor
left side PTO that extends from rear IPTO and terminates at front left of tractor
center PTO that begins from left center and terminates at front center. It penetrates the front crossmember of the front fast hitch
two left side PTOs that run perpendicular to tractor centerline.
tube and shell heat exchanger that picks up heat from tractor coolant
front hydraulic pump
three more IH hydraulic valves and reservoir fed from the front pump
two air valves, cylinder, and 12v compressor to control IPTO. I now get to ditch the big PTO lever
hydrostatic steering because the standard drag link was giving me headaches. It was always in the way.
suppose I could add the convertible traction aids and winch (which are coming off), front weight bracket, relocated battery, and the five hydraulic cylinders for the front fast hitch and the folding ice cream freezer station that will handle 10-15 freezers.
I have probably forgotten something. Whatever you do, please don't make any suggestions for additional attachments. I need to suppress my latest idea. A PTO driven LED sign that will rotate high above the tractor. Kinda like a helicopter. It's a good thing I don't have an extra Electrall gearbox hanging around.
