Re: c won't turn over
Posted by gene bender on October 14, 2010 at 03:43:36 from (67.55.227.196):
In Reply to: c won't turn over posted by dusty dog on October 13, 2010 at 16:47:14:
Its not a stuck valve as they cannot hit the piston. Are you sure it isnt locked in two gears. It should turn over with the clutch pedal down. You can move the pistons some so its not stuck tie the clutch pedal down and try again. The clutch disc couldalso be stuck fast to the flywheel. Tie the pedal down and use the crank with it in gear if the tractor tries to move the disc is stuck.
