Re: Re: Re: IHC 400 Radiator
Posted by Answers effort on June 20, 2000 at 22:21:32 from (207.177.47.153):
In Reply to: Re: Re: IHC 400 Radiator posted by Rich on June 20, 2000 at 08:50:30:
Rich- I honestly don't know the recommendation for grease in that upper gear box. My 450 was dry when I took it apart and that added to my cynical attitude about Farmall design issues. More on that in a minute...
My recommendation is to give those gears and that new bearing a heavy dose of plain old gun grease. Gear lube will leak away, down the vertical shaft.
You are into a complex job and spending a bunch of money already, so go a few more bucks and just do all belts and hoses brand new while you're in there. Put the old belts on a nail in the shed, as "emergency spares", and you'll never, ever, need 'em. If you don't, within 6 months you'll be tearing the thing down again to replace at least one of 'em! In so many words, create your own good luck.
The radiator should have a pair of rubber pads between it and the cast iron it mounts onto. The two long studs should have springs on them and the radiator should be able to "flex". Cut up an old radiator hose and you got the rubber pads as a freebie.
The fan shroud really "got under my skin", as to the hassle of removing it. I cut away the bottom 1/4 of mine, leaving two sides and the top, then split that down the middle. I now have just two easy to R&R fan shroud pieces.
Don't know about your politics and religous beliefs, regds birth control and abortion, but mine involve thinking that the world could be a much, much, better place if a time machine and a killer team were available.
Ponder if we could go back in time and "take out" certain people in history...
After several years of slow renovation work on my 450, I'm seeing Farmall designers and corp. officials as a good place to start that project! Last time I posted about this idea the replies sounded like we'd need at least a CH-47 Chinook from the old 228th to haul all the killer team volunteers.
Rich, good luck and my wish is that you won't need it! Grins, IHank
Post A Followup
: Re: Re: Re: Re: IHC 400 Radiator
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
