Re: International cub tractor with Howard creeper gear.
Posted by Gator809 on October 14, 2010 at 12:18:10 from (66.210.61.254):
In Reply to: International cub tractor with Howard creeper gear. posted by R. Foster on October 14, 2010 at 09:03:58:
I agree, It has most of the extra parts the Steep Slope cubs had, it's only missing the duals, and they also included a set of the Cub wide adapters to make it even wider. Mine is 73" from tire to tire. The front axle was made just for them also, and the hubs are off a hay wagon I think, and are running 15" rims and flotation tires.
The parts for the right side despeeder, the modified brake petals, the platform extension, the modified seat frame, were only made for these cubs.
Another feature is unlike a normal Lo Boy, the rear final drives are rear facing, instead of front facing, it uses a special bellcrank to actuate the brakes running under the final.
I just hope a collector gets it, and not a person buying it for parts.
