There are several different size belt pulleys seen on an H. You need to match belt speed in ft per min to the machine for good performance. If you run too large dia pulley on that H it will not perform well. To small a pulley and machine will not perform. I have no idea what speed the seperator should run , just know that on the older combines it was beater speed that determined if you were operating at correct rpm for rest of machine.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
