Re: H on a Thresher Revisited...
Posted by Pale RIder on October 14, 2010 at 21:00:26 from (207.200.116.5):
In Reply to: Re: H on a Thresher Revisited... posted by randy hall on October 14, 2010 at 12:21:39:
A longer stroke be it a gasoline engine or where it is more often seen in a diesel engine is what generates the significant power. Something like a two cycle dirt bike has a very short stroke because it is how rapid acceleration is derived by the rapid full cycle rotation time which is inherent. It depends what the engine is used for as to which is important and which is used.
