Re: need to find the hydraulic drain for a 300 utility
Posted by Janicholson on October 15, 2010 at 06:01:28 from (67.72.98.45):
In Reply to: need to find the hydraulic drain for a 300 utility posted by Mathias NY on October 15, 2010 at 05:52:57:
In the reservoir at the front right corner below where the front control valves are, or would be, located. It is pretty small, and located where there is no good way to keep it from being messy.
A rubber or vinyl hose screwed into the threads can help get oil into a container. A pipe would also work to get the oil away from the side of the tractor casting. (Best of my memory) Jim
