Re: Regular Farmall Float
Posted by 36F30 on October 15, 2010 at 18:12:40 from (71.214.217.123):
In Reply to: Regular Farmall Float posted by 440 six pack on October 15, 2010 at 16:47:29:
The float should be 7/16 to 29/64 inch below the rim on the model R carb. Easiest done with the bowl removed and upside down. you can then put something through the bottom (top upside down) to hold the float arm and then push on the screw to bend the arm to adjust. I got an old screwdriver i bent to fit in and clear the float. A strait tool just won't quite work. Hope you got a brass replacement, I don't much care for the cork ones. Good luck
This post was edited by 36F30 at 18:14:05 10/15/10.
