Re: saginaw hitch for 1948 H
Posted by KenB_Texas on October 15, 2010 at 19:43:55 from (216.82.216.252):
In Reply to: saginaw hitch for 1948 H posted by narrowfarm on October 15, 2010 at 07:26:09:
A few silly questions if I may?
When you install the 3 point and leave the draw bar on how do you get the bolts lined up on the draw bar holes and the hitch at the same time? Is it a a matter of being a balancing act. Cause when you loosen the bolts doesn't the draw bar fall off?? Is there a trick to it I am not seeing?
What are the advantages of floating 3 point?
What are the differences in the 3 pinning holes at the top mount for the top link?
thanks
ken
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
