Re: need to find the hydraulic drain for a 300 utility
Posted by 510 plows on October 15, 2010 at 20:00:56 from (206.9.209.155):
In Reply to: need to find the hydraulic drain for a 300 utility posted by Mathias NY on October 15, 2010 at 05:52:57:
On the International 300 that I'm restoring there is a 3/8 pipe plug on the left side of the reservoir under the anchor for the hitch cylinder. Kind of hard to see, you need to stand on your head just to see the pipe plug.
On the I-300 parts tractor that I used for lots of stuff this same port was being used for the return oil from the power steering unit to flow back to the reservoir. On that tractor I disconnected the power steering line to drain the oil.
Happy hunting.
