Re: McCormick W-6, checking oil level
Posted by The Red on June 21, 2000 at 09:14:16 from (206.246.187.2):
In Reply to: McCormick W-6, checking oil level posted by Alex Burachynsky on June 21, 2000 at 08:41:54:
Since that is basically an M engine, there should be two check valves on the oil pan on the distributor side. Oil level should be no lower than the lower check valve and no higher than the upper check valve.
Post A Followup
: Re: Re: McCormick W-6, checking oil level
