rear steel hydraulic lines on farmalls
Posted by jcwag on October 16, 2010 at 08:06:03 from (75.194.212.186):
just wonering if anyone knows a good way to replace the rear hydraulic lines on the farmall 300-350-400-450 series that run alond the right side of the battery box. my brother did one 15 yrs ago or so, he cut out the bad spot and took the same size line to fill in then took the next size bigger and slipped it over the top of the joint and braized it closed, but it dosnt look quite correct. any ideas??
