Re: Farmall H How To Change Magneto
Posted by ScottyHOMEy on October 17, 2010 at 06:44:12 from (64.222.203.150):
In Reply to: Farmall H How To Change Magneto posted by Brit2010 on October 16, 2010 at 20:50:27:
Just to add to Tom's clear and excellent advice, it couldn't hurt to turn your motor over so that it's set up at TDC on the compression stroke on #1 begore you remove your existing mag -- you can verify with the timing marks, by checking the top of the #1 piston, and by checking that the rotor is pointing to your #1 plug wire -- which will leave you set up for final timing of the mag.
