Re: 706d stalling
Posted by pete 23 on October 17, 2010 at 11:10:17 from (184.12.32.90):
In Reply to: 706d stalling posted by Russ from Canada on October 17, 2010 at 10:23:11:
Is it a 282 or 310? Eiether one, take line off at pump from filter to see if you get a good flow of fuel, if not work back toward tank. If ok, on a 282, take off the top fuel return line fitting, whole fitting out of top of pump and see if check valve has bits of plastic in it indicating failure of govenor shock absorbing ring. You could try running it without fitting, just to check to see if that is the problem. The 310 doesn't have that problem.
