Re: serial number, Farmall A
Posted by AG in IN on October 17, 2010 at 14:05:46 from (67.236.66.226):
In Reply to: serial number, Farmall A posted by neil P. on October 17, 2010 at 13:44:41:
I don't know offhand when the serial number plate was moved to the seat frame. I have a '46 and that's where it's mounted. Serial number plates for early A"s and B"s were riveted to the cover below the fornt of the platform. Many of these are missing the serial number plate or the cover itself. The cover hides some of the return springs, pivot points, and linkages for the pedals. If you can find some letters on castings or an engine serial number, the year of production can be narrowed down a bit. Also, does it have a rubber shift knob? How about a 1 1/8" diameter PTO shaft? Do both rear wheels have the lighter centers or is the right side heaver looking, almost like a wheel weight? AG
This post was edited by AG in IN at 14:16:14 10/17/10.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
