Re: Cub ammeter jumping
Posted by Janicholson on October 17, 2010 at 15:28:57 from (67.72.98.45):
In Reply to: Cub ammeter jumping posted by dougct on October 17, 2010 at 14:24:54:
Normal and normal.
the mechanical regulator is very "noisy". It makes dramatic electrical static which is reflected in the meter. Some meters have a dab of resin that dampens the movement, some have had the damper resin get old, some never had it.
Three choices:
Ignore it, it isn"t broken
Replace the meter with a high quality replacement with internal dampening
Put a 20mfd 20 volt capacitor (or there abouts) across the meter terminals.
Jim
