Posted by farmallhal on October 17, 2010 at 17:40:08 from (76.2.190.240):
In Reply to: Farmall C or Super C??? posted by Matt from PA on October 17, 2010 at 15:47:48:
Another identifying item are the brake and clutch pedals - if they are straight and not curved to be closer to you as the operator it is a straight C. The Super C has curved back pedals. I believe both had touch control units unless they were factory deleted by the purchaser, Hal.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
