Re: brakes 300
Posted by Jimmy King on October 17, 2010 at 21:03:21 from (66.119.9.207):
In Reply to: brakes 300 posted by Telker on October 17, 2010 at 20:20:25:
Take them apart make sure nothing is broke springs, expanders, clean them real good may very well need new disk. also the splines on the pinion shaft could be wore enought to keep the disk from moving when you step on the breaks.
