Posted by Roy in NY on October 18, 2010 at 12:10:41 from (74.32.155.121):
I have a tank heater I want to install on my IH 434. where are the best places to make the connections? I see the radiator has a tap on the bottom tank for the cold water connection where is the best place for the hot side to be connected to?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
