Re: Farmall 350 utility PTO install?
Posted by Janicholson on October 18, 2010 at 13:28:55 from (199.17.6.223):
In Reply to: Re: Farmall 350 utility PTO install? posted by Pat Connors on October 18, 2010 at 12:41:02:
Look at the serial tag and the suffix letters there. it may be a trans drive PTO as noted below.
Check that and also if it has no TA it is less likely to work. Also if that shaft will spin with the main clutch pushed down, but not with the clutch engaged, it is a non live PTO tractor. if it will not spin unless the engine is running and is not affected by the clutch, it is probably a live PTO system on the tractor.
One last thing is the New PTO equipped with an axle mounted lever that operates a cylinder shaped linkage on the side of a rather large housing with a Pnut shaped small cap on top? If not it might be a non live new PTO. Jim
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
