Re: Farmall 350 utility PTO install?
Posted by Wardner on October 18, 2010 at 17:55:51 from (4.154.235.230):
In Reply to: Farmall 350 utility PTO install? posted by Pat Connors on October 18, 2010 at 11:20:26:
Your first step is to look at the serial number.
The suffix tells you what's inside.
P=IPTO without TA
R=Transmission PTO with TA
S=IPTO with TA
There are no common parts between the IPTO and the transmission PTO. And that means all the way up to the main clutch pressure plate.
When you find out how your tractor was built, go to the on-line parts book to see what you need.
