Re: '48 C leaking rear end oil
Posted by Milan D. Radakovic on June 21, 2000 at 15:59:36 from (209.69.204.12):
In Reply to: '48 C leaking rear end oil posted by Clint Proeschel on June 20, 2000 at 17:37:07:
The leak at the belt pulley is an easy fix.. Drain the oil out from the pulley/pto housing. There's a plug at the bottom of the housing. remove the bolts that hold the side cover where the belt mounts, and take the covber off, clean it and permatex the cover, and put it back together.
The axle leak, you'll have to remove the wheel, then remove the cap at the end of the axle housing (the part with the grease fitting), inside there's a grease seal, which you'll have to replace with a new one.
Post A Followup
: Re: Re: '48 C leaking rear end oil
