I have the tank you want to see. Not mounted and not going to be for a while though. If you are shopping these make sure you get the right one, though. The addition of hydraulics on the SA created a conflict with the rear most mounting bracket on the tank. While it is reasonable to assume that a SA starting tank would fit an A/B the reverse may not be true. For a certainty I can tell you that my S/A tank does not fit my SAV. Not an issue, though as I have a B with shutters and the correct hood so I will simply be putting it on there. If no one else comes up with a pic I will try to get one of mine and post it later today.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
