Are you saying there are two holes in the case? One for the wire and one for the bolt that holds the points spring and the wire for the condenser?
If this is the case, either it is not an IH distributor or someone has fudged something and drilled an extra hole for the wire for reasons unknown. The correct connection is to have that wire attach to the bolt on the outside of the case. If the wire comes through a hole and connects to the same bolt on the inside, it should be electrically correct, but anyone who opens it up and looks at it is going to scratch their head and go "Huh?" (The bolt is not grounded--it passes through a plastic or fiber insulator so that it does not ground to the case.)
This post was edited by TheDurk at 09:17:40 10/19/10.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
