The voltage to which it can raise the battery (from 6.3 setting to near 7 and over) as Hal pointed out at RPM is a good charging test. Make sure the belt is good n tight and BOTH the Genny and VR (or headlight switch if its a cutout relay system) have good grounds. If when shes running you use a jumper to temporarily dead ground the gennys FLD post that allows for max charge independant of any Light Switch or Voltage Regulator problems so see how she charges then???? If she charges strong with the FLD post grounded but NOT otherwise the problems either in the LHBD light switch or the VR or the VR or switch has a bad/resistive ground.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
