Re: Adding live hydraulic pump on plain M
Posted by usetabesteve on October 19, 2010 at 11:06:59 from (168.166.54.11):
In Reply to: Adding live hydraulic pump on plain M posted by CenTex Farmall on October 19, 2010 at 10:56:30:
The easiest way to do this is with the power steering pump from a half-ton GM pickup truck. It's easy to install and easy to plumb.
Unless you have a late 1950 or 1951 M, you have the older cam drive gears. The old gears will run the add-on pump from M&W gear ok but not the IH pump. You need the later gears from a Super M, 400, or 450 for the IH pump. If the cam has been changed you could have the later gears. If you want to use a distributor mounted pump and have live hydraulics in addition to power steering from that pump you will also need the priorty valve.
