The only way to fix that is to have a machine shop bore the cracked cylinder, press in a repair sleeve which will then seal the crack, and then bore the repair sleeve to fit the replaceable sleeves. This fix is expensive so you may be better off buying a replacement engine block.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
