Re: super a steering
Posted by TheDurk on October 20, 2010 at 09:01:58 from (71.125.79.85):
In Reply to: super a steering posted by van strom on October 19, 2010 at 10:45:42:
Before you get in there, if you have not done so, make sure EVERYTHING outside the box, from lug bolts to steering wheel nut, is good and tight, including the steering arms and the nut on the bottom of the vertical shaft coming out of the box. An imperceptible amount of play in these areas can add up to a perfect mimic of a sloppy box. Do the easy stuff first and you may not have to go in there at all.
Apologies if you've done this already...
