Re: Farmall H Schwartz Wide Front End to Farmall M
Posted by RPM1941 on October 20, 2010 at 21:10:49 from (173.25.70.110):
In Reply to: Farmall H Schwartz Wide Front End to Farmall M posted by Larry in WNY on October 20, 2010 at 09:29:54:
The entire axle is not strong enough if you plan on using it hard, Schwartz wasnt made of hardened steel, it will fit if you redrill every mount hole, biggest fault is the small spindle & wheel bearings on H, M much bigger.
