Check for battery voltage at your coil. With the points open and the ignition swith in the on position you should have battery voltage on both small terminals on your coil. You need to use a volt meter or a test lite. If there's no voltage present on the coil you need to check your ignition switch to see if voltage is there. Could be a broken wire or loose connection. Run a separate wire from your battery to your coil then see if the engine will start. You know it will crank if the engine spins over when trying to start it. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
