Re: 1941 H Farmall not strating Help
Posted by mkirsch on October 21, 2010 at 05:05:01 from (64.80.108.57):
In Reply to: 1941 H Farmall not strating Help posted by BEN MURPHY on October 20, 2010 at 17:38:40:
"Not cranking" means the engine is not moving. If the engine isn't moving you will never get a spark.
We need clarification here, though I suspect that the engine is cranking just fine. It is not firing.
If the engine is cranking, but not firing, you probably blew a wire off somewhere with the pressure washer.
One other thought: Did you forget to turn on the ignition.
