Posted by mkirsch on October 21, 2010 at 05:18:20 from (64.80.108.57):
In Reply to: #8 2 bottom 12 plow posted by james williams on October 20, 2010 at 05:08:46:
No, it would not cut 14".
Cut is about where the plow is set to run, not the length of the share.
The front bottom will hang into the previous furrow by 2". It will only cut 12".
The second bottom is spaced 12" over from the first, so it too will only cut 12", and it would hang into the front bottom's furrow by 2".
On Super Chief, the only difference between different width bottoms is the share/point. They all have the same frog, same moldboard, same shin, same landside.
If it really bothers you, you can torch 2" off the share/point, but I'm telling you it won't make a bit of difference.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
