Re: IH-1000 loader questions
Posted by bc on October 21, 2010 at 11:10:52 from (64.123.118.94):
In Reply to: Re: IH-1000 loader questions posted by mkirsch on October 20, 2010 at 09:46:54:
Hello M. My IH-3000 loader has the same symptons as the no down pressure you are talking about. Either rides up or digs in when I tilt the bucket. As far as I know, I've got up and down pressure cause I can raise the front wheels off the ground when I use the hoe.
Is there something I can do such as R & R the valve assembly or something? It has a float position on it which seems to work when back dragging or when I don't have the bucket tilted so the edge catches.
To make matters worse, when I try it with the bucket tilted all the way down so it acts like a blade, the left side seems to be a couple inches lower than the right. If I barely want to skim the surface, it only does it for part of the bucket width and then if I drop it down to get the right side to skim the top, the left side digs in. Is there a way to level the bucket up?
Thanks for any help.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
