Re: Farmall 100 smokes thru breather
Posted by T16 on June 21, 2000 at 21:17:08 from (206.10.96.165):
In Reply to: Farmall 100 smokes thru breather posted by Bill on June 21, 2000 at 19:30:59:
Most tractors emit some smoke from the breather.
It sounds like either blow-by or possably a cracked head gasket, chances are it's blow-by, caused by normal wear, piston rings ain't sealing as good as they should.
Does it smell like exhaust or burnt oil?
Possably could be a real bad valve guide, but chances are you would hear that clattering away.
A bad head gasket would have to be bad into the oil cavaties and would usually cause enuf pressure to blow out a main seal or valve cover gasket.
Good Luck! Hope this helps out.
Post A Followup
: Re: Re: Farmall 100 smokes thru breather
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
