Re: Farmall H- Clutch Sticking?
Posted by old on October 21, 2010 at 12:57:26 from (4.245.10.218):
In Reply to: Farmall H- Clutch Sticking? posted by Faster346 on October 21, 2010 at 12:19:05:
Common problem with tractors. A couple of things you can do which should help are. #1 block the clutch down when ever it is parked. #2 block it down and let it sit and run for an hour or so with it in gear. That will help clean up the flywheel and pressure plate a little bit. #3 pull the starter off and spray the clutch area with brake cleaner. Slowly turn the engine over at the same time to get the brake cleaner all over the clutch
