Re: More ideas and questions on BA
Posted by gene bender on October 21, 2010 at 13:08:39 from (67.55.227.196):
In Reply to: More ideas and questions on BA posted by old on October 21, 2010 at 12:52:44:
The sruds will be long enough. With the center dished out and a wheel wt is would be fine also. You can set tha left wheel out pretty far by using the wheel position on the reversed center. You can also add wheel wts they weigh 142lbs. The inside dual mite not stak thght as the hole is tapered and only the outside one will fit the tapered stud but i would think it should work. Try it and see if the inside one has any movement. Why couldnt a lock washer berween them be ok. I can send some lock washers if you want some.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
