Re: Re: Bent oil pan
Posted by Bama Binder on June 22, 2000 at 05:56:29 from (206.5.110.15):
In Reply to: Re: Bent oil pan posted by TomH on June 21, 2000 at 17:28:52:
Thanks for all the replies. I fully intend to correct the oil pan problem, but in this case, I guess I should tell you that the tractor has not run in about 3 years. I just bought it and have no idea how long the previous owner ran it that way.
So far I am still working on getting it running again. It has good compression and I just re-built the carb. I am in the process of replacing all of the ignition components, so it should run soon...then on to the other problems...I think the list is at 12 items that I think need fixing...
So much for bargain basement tractors.
Post A Followup
: Re: Re: Re: Bent oil pan
