Re: Farmall M clogged fuel line
Posted by Bob M on March 12, 2009 at 08:19:37 from (151.190.254.108):
In Reply to: Farmall M clogged fuel line posted by MN Tim on March 12, 2009 at 07:50:12:
Tim - There should be 2 fuel strainers that require attention:
1 - The sediment bowl strainer. It's a round screen fitted between the glass bowl and the gasket. (Sometimes this screen goes missing...)
2 - The carburetor inlet strainer. This is small tubular screen attached to the backside of the fuel inlet nut. It can be removed by disconnecting the fuel line at the carb then unscrewing the large hex fitting (the fuel inlet nut) behind it.
After cleaning both screens and before reconnecting the fuel line, suggest draining a cup or two of fuel thru the open fuel line to flush out any rust, etc. that might be in the line. Also if you can get the drain plug out from the bottom of the carb bowl, remove it, turn the gas on and let a cup or two of fuel flush thru the bowl then replace the plug.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
