Re: 1944 h with heat houser pics
Posted by Janicholson on October 23, 2010 at 09:23:24 from (67.72.98.45):
In Reply to: 1944 h with heat houser pics posted by ericy on October 22, 2010 at 07:21:08:
You did an amazing job on the frame (I can tell because the fabric is applied somewhat better than it is on a standard frame!! Very nice job.
The windshield can be made from a piece of lexan polycarbonate (.093") from Menards or other sources (do not use plexiglass, it is not the same at all.)
THe polycarbonate will easily bend to fit a frame made from 3/4X3/16" strap bent to follow the H-H contour, and tabs made to attach.
Use 6-32 Fillister head screws to mount the plexi to the frame. Put threads in the frame holes and loos fit holes in the poly. use a rasor saw to cut off the excess bolt length, or purchase bolts with the exact length to avoid sticking out on the front side. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
