Don't have Nebraska tests in front of me, but I believe the gas-powered F-12 put out a bit more than shown in the entry here. An F-12 was my "first tractor," which I started steering before I could reach the clutch, shortly after my father bought the tractor new in 1938. In a few months, I could scrunch down enough in the seat to start and stop the thing. I see mostly praise for the tractor in the comments here. This was an absolutely great tractor for its day. Not the most comfortable, but not bad. The engine was one of the earlier designs for using increased engine speed to get power, rather than dropping in a humongous engine that ran at low speeds. I give partial credit to full-pressure lubrication for the engineers' willingness to go to higher speeds (I have a little Ford 1100 that will turn up 3000, and it is as reliable as they come!!). The Farmall H goes the same route (aside: a dealer told my father in the early 1940s that the H would tear itself apart because it ran so fast! We had two, and they were as reliable as any tractor made). The tradeoff is not much torque, but tractors designed this way use gearing to get the needed torque to pull their "rated" loads. In the approximately 25 years that my father used this F-12, I don't think any repairs were made other than the replacement of a couple of fuel pump diaphragms. In its earlier years, we used it for all kinds of heavy work because it was so much more comfortable than the steel-wheeled 10-20 that was still on the farm. I never saw any sign of structural weakness in the engine, gearbox, frame, axles, etc. And, for all that some might say about the lack of power, we need to take into account the difference between steel wheels and rubber. Our F-12 on rubber pulled almost the same load that we used to put behind the 10-20--a double 12" plow or a 7-ft. double-disk harrow (the 10-20 pulled 2-14s; never tried that behind the F-12, but I suspect it would have done OK in moist soil in second gear). The F-12 governor was "snappy"--within the load range of the tractor, the governor was very responsive. I used to cuss at the slowness of the tractor, but it was slow because it was designed in the early 30s for steel wheels. Hauling a hay wagon for a mile to the barn was a pretty leisurely process. The 7-mph 3rd gear would have made this a nice hauling tractor on the rough country roads of the forties.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
