It runs but still a lot more to do (BA)
Posted by old on October 23, 2010 at 13:52:24 from (4.245.14.213):
Yep got the piston problem fixed and the head on today. Hot wired it and use a small tank for fuel and got it to start. Smokes pretty bad right now but I figured it would since I had ATF in the cylinders. Carb has a problem with the float sticking or the needle not seating as it should but that was to be expected. Still have to put on all the cooling system stuff and valve cover etc etc etc. But at least I did get it to start and run for a few minutes so now on to the stuff that really takes a lot of time to do and also have to wire it since it has NO wires on it right now
