Posted by gene bender on October 23, 2010 at 16:46:27 from (67.55.227.196):
In Reply to: OT posted by James Williams on October 23, 2010 at 12:13:51:
Are you sure the hole are for a soleniod and not a sadle mount and someone put in a stud instead of the button some have been changed that way i have one or more like that. Is the Delco-Remy tag still on the starter you didnt say what engine the starter is for.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
