Posted by John T on October 24, 2010 at 16:31:41 from (66.244.97.31):
In Reply to: Cub generator posted by oldfarmer on October 24, 2010 at 15:05:42:
I agree with the Rusty one, Ive seen 3 brush gennys that used VR's and others that used Cutout Relays. If changing from a relay to VR, one might want to adjust the third brush (if its adjustable) for the max charge setting as the new VR will take care of regulation. The other option is use of a 3 (BAT ARM FLD) terminal versus a 4 terminal (BAT FLD LOAD ARM) VR and Bobs diagrams should cover either choice, the 3 is simpler to wire up. You no longer (if you swap relay for VR) run any wire from FLD on the genny up to the LHBD light switch if thats what it had
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
